AutoCAD LT General Discussion
Member
0 Kudos
Post 1 of 12
Accepted Solution
Non coplanar lines
2981 Views, 11 Replies
03-05-2012 04:19 AM
Can anyone explain non coplanar lines to me - when I try to fillet I get a message on the command line saying "lines are non coplanar"
Also when drawing hidden or dashed lines they are at different scales - can anyone help me out
From the Command line:
CUI
In the Left pane near the middle you should see a Star with an Red/Orange asterisk
Click this for new Command
Copy and paste the Macro in the right pane where it says Macro
Give it a name: Flatten would be good
Click Apply
Go back to the Command list
From the Upper left Pane
Expand Partial Customization files
Expand Ribbon
Expand Panels
Expand your favortie Panel
Drag your new Command (Flatten) from the lower pane to a Row on your favorite Panel
Hit OK.
Should do it. Plenty of YouTube and Google tutorials out there on adding a Command.
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
*Expert Elite*
370 Kudos
Post 2 of 12
Re: Non coplanar lines
03-05-2012 04:43 AM in reply to: chrisraemers
Select the line or LIST Command the line.
Is the a Z coord other than zero?
If so place this on a Button to run this Macro on your drawing: -Flatten Z coordinate:
^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
1,605 Kudos
Post 3 of 12
03-05-2012 08:13 AM in reply to: chrisraemers
FILLET only works on objects that lay flat in the Z direction (yes, LT has a 3rd dimension other than X and Y). Select both lines, start PROPERTIES command and type in 0 (that's a zero) in Start Z and End Z boxes.
Explain the other question in mode detail: or use PROPERTIES again and ensure both lines have the same LINETYPE SCALE (1 ideally).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 4 of 12
03-05-2012 09:41 AM in reply to: chrisraemers
Thanks for the help Guys - that sorted it for me.
Member
0 Kudos
Post 5 of 12
03-05-2012 09:57 AM in reply to: Charles_Shade
Hi Charles
I've managed to select two individual lines and set the Z coordinate to 0 so that they fillet but I assume with your Macro, I can pick all lines and move them to 0.
Can you explain how to place the macro on a button to run the macro?
Regards
Chris
*Expert Elite*
127 Kudos
Post 6 of 12
03-05-2012 10:01 AM in reply to: pendean
Coplaner only means that all of the Z values are the SAME.  They don't HAVE to be equal to 0, they could just as easily all be equal to 155.17 if that was correct for the model. But if your model is 2D then zero is your hero.
:smileyhappy:
Dave.
Dave Hein, P.E.
*Expert Elite*
370 Kudos
Post 7 of 12
03-05-2012 10:09 AM in reply to: chrisraemers
CUI
Click Apply
Expand Ribbon
Expand Panels
Hit OK.
*Expert Elite*
127 Kudos
Post 8 of 12
03-05-2012 02:54 PM in reply to: Charles_Shade
>... ^C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0​,-1e99; ...<
If I run this as it is in AutoCAD 2011 it doesn't work.  If I replace the "_p" with "_all" it does.
Dave.
Dave Hein, P.E.
*Expert Elite*
370 Kudos
Post 9 of 12
03-05-2012 06:39 PM in reply to: heinsite
Yes but does not Full have a utility for this OOTB?
This Macro is our LT work around.
I believe it to be the Express Tool: FLATTEN
*Expert Elite*
127 Kudos
Post 10 of 12
03-05-2012 07:30 PM in reply to: Charles_Shade
I'll have to look tomorrow when I go back into work.  That's where I was when I posted my last reply... but I didn't look!  :smileysurprised:  I was just focused on the macro and figured if it worked in LT (which I have at home and on my laptop) it would work in the full version.  But it got tripped on the _p (previous) command.  So I changed it and it seemed to work fine.
I'll mess with this some more... It wouldn't surprise me if I still messed something up!
Dave.
Dave Hein, P.E.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
