When I try to use the vport command or the custom view port scale command the program acts as if I am using the command but no window pops up to allow me to make any changes to my view ports or create a new view port scale.
Solved by pendean. Go to Solution.
Did you recently change from a dual screen setup?
Or resize your Windows display?
Start that command and then hit ALT+Space bar and then M
Use the arrow keys to see if you can reposition the command window back on screen.
Make sure to complete the command by clicking OK to save the window location.
OR
http://www.texupport.net/blog/2008/02/27/missing-dialog-boxes/
