I'm trying to re-download AutoCAD 2009 LT. I have the emails from when we intially purchased it but the links no longer work. Several places tell me to go to a reseller but we purchased this software directly from you. Thank you
This is a peer supported community so as much as we would like the commission we did not sell you the software.
However; Autodeskers stop by here and offer solutions and downloads for your situation. Please be patient.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hi duffett,
Here are the download links for AutoCAD LT 2009, These links are temporary and will expire in 72 hours, please use them as soon as possible. Also, make sure you save these files for future use as the 2009 versions are no longer within our support range and we may not be able to generate these links again in the future:
Best regards,
Hi, I know this might be a bit late but need to download autocad 2009 Lt 64 bit, any chance the links could go up again ?
thanks
Hi StevenFlower8267,
Refer to the download link below which was set to expire in 30 days.
Welcome to the community David!
I've just sent you a Private Message (little envelope next to your profile name when logged in) with the requested link.
Please let us know if we can be of additional assistance!
Thanks for the reply Phil. Unfortunately, I guess my product is not on subscription so I can't get to the download link. Is there anyway to access this without going through the subscription page? That 64bit link lets me start downloading, but I don't need 64 bit. I appreciate your help.
Dave
You're welcome Dave!
So the Subscription Center login prompt is associated with a link that has timed out and is no longer valid.
The one I sent you in the PM should be good for 30 days / I tested on my end to make sure it was functioning properly. With that being said I've just resent it as a hyperlink which should clear up any confusion.
Please let me know if it works for you!
Hi aocautocad and welcome to the forums!
Here's the link:
Best regards,
I have license for AutoCAD 2009 LT & AutoCAD 2011 LT
but i lost CD for install and still not have permission to buy new version.
Please give me link for download setup file
AutoCAD 2009 LT and AutoCAD 2011 LT
If you are just looking for an LT2011 download you should be able to find it at the Autodesk Customer Service Virtual Agent:
•In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
•In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
1. Turn off your personal firewall or VPN, if you use one.
2. Disable UAC
3. Close and reopen your preferred browser.
4. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
5. Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
DWGTrueview 2014 download links can be found in this post:
http://forums.autodesk.com/t5/Installation-Licensing/TrueView-download/m-p/4427763#M68123
