I am drawing on a large commercial facility plan received from an Italian designer drawn in centimeters.
I would like to continue to draw in centimeters, but would like my dimensions to appear in feet and inches to the 1/2 inch.
Please help!
Thanks!
Solved by pendean. Go to Solution.
Solved by sthompson1021. Go to Solution.
You will need to set up a DIMSTYLE that uses architectual as units has a conversion factor of .3937
