AutoCAD LT Forum
Need help with Dimension conversion!
3 REPLIES 3
cwolf0601
282 Views, 3 Replies
I am drawing on a large commercial facility plan received from an Italian designer drawn in centimeters.
I would like to continue to draw in centimeters, but would like my dimensions to appear in feet and inches to the 1/2 inch.
Please help!
Thanks!
3 REPLIES 3
sthompson1021
in reply to: cwolf0601
You will need to set up a DIMSTYLE that uses architectual as units has a conversion factor of .3937
pendean
Assuming you will add your own DIMSTYLE for the task... Look up DIMLFAC variable in help, it will set your preset dimstyle to do that if you want.
cwolf0601
in reply to: sthompson1021
thanks!
”Boost
