Hello !
I usually open several drawing and use"drag and drop".
But somthing has happend.
Now, I can only open one drawing at the time. When I try to open the second drawing, the program close down the first.
What have I done ? and what shell I do ?
Help !!
Stellan Fors
Solved by PatrickByrne. Go to Solution.
The AutoCAD variable is SDI. Type SDI on the AutoCAD command line and set it to 0.
Patrick
http://www.multi-batch.com/
For your entire batch processing needs
Thanks a lot !!!
Now it works lake it allways have.
I gues I have done some short comand wrong.
Thanks again !!
Stellan
If Patrick Byrne's post answered your question, then mark it as "Accept as solution" so people know the question has been resolved.
Also, Welcome to the Forums!
When I have two or more drawings open, the program becomes unstable and the lower right hand corners keep flashing? It only does that when I have more the one drawing open. I am running LT 2014. Please help.
Welcome to the Autodesk Forums!
Proxy Objects in two open drawing files may be the issue.
The link is to a Thread on the subject:
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2014-Flickering-Issue/m-p/3875348#U3875348
Message 40 is the first to pay attention to in that thread.
Message 38 sends you to another Thread where you will begin to read about replacing a file at messsage 21:
http://forums.autodesk.com/t5/AutoCAD-LT/AutoCAD-LT-2014/td-p/3821690/highlight/false
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
