Hi there, I am using a multiple line attribute. I insert the block, fill in the text, and adjust the width of the multi-lines text so the lines are longer and there are fewer of them. I save and close the file, then re-open some time later and the width of the multli-ine attribute has reverted back to a different width (shoter) - I am assuming it is the default width that I set to the attribute. Is there a setting to stop this from happening? Is there something I should do when I create the attirbute?
Thank you.
You don't mention how you "adjust the width of the multi-lines text", and whether the "different width" is actually the original width. Posting a file with the block may help others help you too. LT2012, right? You should always note it in any post.
Fair enough. My apologies. Actually I at this time I do not have a drawing to give an example. In the instance I was referring to there was actually no glitch, but raher a user error when using the Find command to replace text before closing and re-opening the file - the change lengthened the text and the result ws an extra linein the attribute.
However, I believe I have seen this problem in the recent passed. If I come across it again I will definitely opst a drawing to be reviewed.
Again,my apologies!
