When creating drawings I use the DIMTEXT 25 feature. However when creating a Multileader and dragging the arrow
from right to left the leader then underlines the top line. When dragging the arrow from right to left the leader lands correctly in the middle of the top line.
I think it is a setting for landing of the leader however i can't seem to find it. I have attched a file so that the problem is clear.
I have used Qleader and that is fine which makes me think that it is a setting of the Mleader itself.
Any help would be much appreciated,
Callum
Solved by Charles_Shade. Go to Solution.
MLEADERSTYLE
Tap the third tab; Content.
Check toward the bottom where it says Leader Connection.
Fix this to your liking.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Please mark Accept as Solution so that others may more easily find this if they have a similar issue.
