I have created a block comprised of four different attributes. One of those attributes is a multi-line attribute.
After using ATTIPE and setting the value to 1, I was able to edit the line spacing of the multi-line attribute to what I wanted.
Now, let's say I am creating a drawing, and I edit this multi-line attribute to read:
"Building A1
Terrace Plan
-Electrical"
Great! It works perfectly, and looks ok. So, I go on to create six or seven sheets like this. When I create a new set of plumbing drawings, I use Find and Replace to change "Electrical" to "Plumbing."
Unfortunately, using Find and Replace on my multi-line attribute appears to uncheck my Paragraph Line Spacing. Is there any way to correct this behavior?
Not at this time from what I can tell. If no one else offers a fix then be sure to report this bug to Autodesk, posting here is not the best solution:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
If you are a subscription user, you can report through the Subscription Center as well (as in do it twice).
