How do I make a leader, no text, no landing, grippers on both ends. Everytime I go to grab the gripper on the non-arrow side of the leader it moves away from me (I believe I am talking about stretch point, but not sure. The line just moves away from the pointer at an ever increasing speed and distance).
Solved by sthompson1021. Go to Solution.
Solved by pendean. Go to Solution.
2013, I have converted to the ribbon because Classic could be taken away at any time.
Or typing MLEADERSTYLE from the Command line would have gotten you there.
Most here will type Commands that can be accessed from the Command Line in ALL CAPS.
No need to hunt drop downs or other menus.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
So that those who are reading will know this is an AutoCAD Command as opposed to a word that is being used.
I can tell you to draw a polyline in CAD which is all well and good but telling you to draw a PLINE will get you going with the Command.
Or as was ppinted out earlier in the thread MLEADER STYLE is not a Command; MLEADERSTLYE is.
Multi leader style is a description.
For future reference, you can start LT's HELP, type the command name, and 99% of the time it will tell you where the icon resides on screen menus. See screenshots and start helping yourself when you can.
