AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
? Move 2015 LT to a different computer
6 REPLIES 6
k_lal00
3895 Views, 6 Replies
I purchased and installed 2015 LT on my desktop computer in May.  I have now realized I need it on my laptop instead of the desktop computer. I know how to uninstall software, but will I be able to reinstall it on the laptop? Is there any special steps I need to take in order to complete this process?
Kris
6 REPLIES 6
dgorsman
in reply to: k_lal00
Theres a tool provided to transfer the license, although performance is a little dodgy.  If not, then you will need to activate the license on the new computer the same as the old one (you might be asked for additional information as part of the activation process if you have activated that license several times already).  For what its worth, you are allowed to use the same license for the two computers provided you don't use them at the same time.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
k_lal00
in reply to: dgorsman
Unfortunately, I have a "desktop subscription" and when I try to use the license transfer utility, it returns a message indicating "License Transfer is not supported" "the license you are trying to export is associated with a license model that does not support license transfers"
Is there another way to move the program?
dgorsman
Just re-install and activate as usual.  You might have to confirm activation with AutoDesk just to ensure you are obeying the license guidelines.  Be polite and concise (they understand these things happen) and you will be on your way in short order.
k_lal00
Thank you.  I have downloaded and installed the trial version, as recommended by an Autodesk support rep.  I can start the program, but it asks for a serial number AND  a product key.  I have a serial number, but not a product key.  I assume this is because I purchased a "desktop subscription"  Regardless, I still need to get the program running on the laptop now.
I have submitted an help request to autodesk as well.
I need to make sure it is working on the laptop, before I remove it from the desktop...
thank you
Albert_Rius
Hi, here you can find the product key for all Autodesk products:
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Albert Rius
Technical Support
Autodesk, Inc.
k_lal00
in reply to: Albert_Rius
Thank you very much!
”Boost
