Dear All
I am having a problem with my mouse wheel function in autocad LT 2011.
The mouse wheel is zooming the wrong way. When I move the mouse wheel forward, the screen zooms out not in! However the mouse wheel is working correctly in other programs, so i believe the problem is in autoCAD LT. Mbuttonpan is set to 1. When I hold the mouse wheel in, the pan works fine.
I have also tried other mouses with my computer, and they all have the same problem.... I'd be grateful if you know how to solve this problem!!
Do you know how to change the defaults so that the zoomwheel setting will always be the same each time I open autocad LT?
ZOOMWHEEL is a Registry setting and should remain as set for all sessions of CAD once it has been set.
Does this not remain so for you?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
