Hi All,
We are having an issue with AutoCad Lt2004. When you put in the command L enter, (or other command) the current working window is deselected (ie greyed out) and I have to click once to get the window back and then click again to select my point on the drawing.
I have so far tried upgrading keyboard and mouse drivers and a different keyboard and mouse. I have also re-installed several times, including clearing the registry of all references to Autodesk and AutoCAD. Both PC's are running WinXP Prof.
Any help greatly appreciated.
