I imported a drawing from another architect. I exploded things and copied it into my base template. Each time I open the file, I get message that is titled Missing SHX Files and says "One or more SHX files are missing. What do you want to do? It indicates that 1 file is missing. I have been clicking Ignore but I am tired of seeing this message and feel that there must be a way to get rid of it. Please advise how to get rid of this message. Thank you.
Solved by Albert_Rius. Go to Solution.
Howard Walker
Hi Alex,
Adding to the comments from hwalker,
You should check the shx file that is missing, then you have next options:
- As for the missing file to your colleague and copy it to your fonts folder
- Check where this font is used, if it's a text font you can go to the style command and chek the style that uses this font and replace for another existing font.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
