AutoCAD LT Forum
Missing Shape Files (Aeccland.shx)
12 REPLIES 12
Message 1 of 13
AaronMillar
21648 Views, 12 Replies
Hi there,
We're using AutoCAD LT 2009, so we of course do not have Aeccland.shx. I am aware that I do not have it. I don't particularly care that I don't have it.
AutoCAD, on the other hand, is very concerned. So concerned, in fact, that it will ask me for this file every time I open projects that involve baseplans shapes from this file. I would like to allay AutoCAD's concerns, and inform it that aeccland.shx is not neccesary, and it can get along quite happily without aeccland.shx, and any other shape file. I would like to do this very much, as I am currently working on a project with 60 or more separate files I must pull information from to compile baseplans I can use.
Does anyone know how to tell AutoCAD not to ask for missing shape files any more?
Thanks for any help,
Aaron
12 REPLIES 12
Message 2 of 13
in reply to: AaronMillar
Ask the file creators to send you this file, along
with their DWG files, and be done with it.
Otherwise there is no fix: to stop the prompt you
need to replace it, to replace it you need to tick off the file
creators.
Talk/Communicate with your files creators, no one
else, to resolve the problem.
Message 3 of 13
There is another, but still extremely painful tiresome annoying, way to avoid this.
Go through the file and remove any reference to the shx file. This will most likely be embedded in blocks, text, points or lines so the best approach is to explode and purge until you have the most basic elements. Then quick select types of objects and change them to known clean styles. Eventually you'll get a clean file, it's about then you get an updated one.
I consider it's actually extremely bad design that you can't get rid of the shx dialog but it appears Autodesk don't.
Robin
AEC Collection & BIM 360 | Windows Surface Book & HP Z6 Workstation | Android Mobile
RobiNZ CAD Blog
Message 4 of 13
bad software design? No, the file content is controlled by the file creator,
no one else. As it should be.
Dean Saadallah
http://LTisACAD.blogspot.com
Message 5 of 13
AaronMillar
> {quote:title=Guest wrote:}{quote}
> Dean Saadallah
I'm afraid I agree with Robin: No option to disable the dialogue seems like an oversight, or a poor decision. Having the shape files does nothing for me other than disable the dialogue, and it would be far easier to be able to tick off "Remember this action" and ignore missing shape files. Most other similar dialogues already do this, don't they (Proxy Objects, Annotation scales, and Layer Filters are the ones I can think of)? I have hardcopies, DXFs, and PDFs to show me the correct looking fonts and notes.
Anyways, your solution and Robin's are the only two I knew of, and it looks like they are the only options. ESC key it is, I'm not going to make other consultants fetch useless files for me.
Thanks for the info!
Aaron
Message 6 of 13
You might feel different if you opened a drawing that required a shape
file, did not get prompted, and then plotted it out, and then have your
client and/or regulatory agency return your drawings because your
linetypes are messed up. The solution is to obtain the shape file or get
rid of the dependency.
If there was a design error, maybe it was the decision to not embed
shapes in the drawing - but there are two sides to this also.
I would be OK with dismissing the dialog, IF there was a comprehensive
"WARNING" area where I could go and review missing shapes, xrefs, fonts,
and other references - but I would want the option to force this upon
users also.
Throwing a prompt at the command line is not enough. I can recall many
times where users complained about that "AutoCAD is using the wrong
font" - when they didn't read the command line to notice that font
substitution had taken place.
R.K. McSwain
http://cadpanacea.com
Message 7 of 13
342-06500465
clean the drawing with purge and make a block of the drawing.
open the block and save the drawing in the original name.
this will do the trick
you will clear all the information in the drawing you do not need
Message 8 of 13
elderla
in reply to: 342-06500465
thankyouthankyouthankyou. I had a .shx file stuck in my custom template, it was driving me crazy! saved the template as a block and it's gone. resaved as .dwt. all is well.
Message 9 of 13
mlara
in reply to: elderla
I have one that works - copy it to your program files - Autodesk - fonts
Message 10 of 13
elderla
in reply to: mlara
mlara: thanks so much. I imagine we all will be glad we have this installed.
thanks.
Donna
Message 11 of 13
mlara
Make sure that the path where this shape file (shx) is properly set in you AutoCAD support file search path in your tools option. To make sure that all your AutoCAD settings are saved, create a profile and save it at a location where you can retrieve it when working on a different workstation or to reload it in case you have to reinstall AutoCAD. Loading your profile loads every settings you made and saves the toolbars and buttons to what ever position you had it.
Message 12 of 13
gorkumyuksel
in reply to: mlara
Thank you so much for posting the SHX file AECCLAND.  It has been bugging me for months and now thanks to you I am at peace.
Much Universal Karma to you!
John
Message 13 of 13
Emmsleys
in reply to: gorkumyuksel
Thanks for posting back and sharing what worked. I don't think the OP will come back to this thread.
I'll go ahead and mark the appropriate post as an accepted solution. Feel free to post back if you have any questions or give kudos to the post or post's that helped.
Sarah Emmsley
Technical Support Specialist
”Boost
