After fixing my corrupted registry (Windows 7) I had to reinstall my Autocad LT 2011. After installing I clicked on the desktop icon and got the message "can not find SCREE.dll" -- startup terminated" What/who/where can I get assistance? Some internet references says that this is an Autocad LT file, but the knowledge base does not have it. Your ideas will be greatly appreciated!!!
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you did not go through this procedure and only if the above fail:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
OK, I removed the files, uninstalled per the instructions. I followed the pre installation instructions then began the install of the 2011 LT. About mid way through the install I got "Error 1606 -". now what do I do? Something is not right and I need to get this issue resolved. I do appreciate your help, so please provide the next step for me to try.
This perhaps? You cut off the full error message http://support.microsoft.com/kb/315352
or these http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=8164400&linkID=9240617&siteID=123112
Post back if you're still having issues.
