The minimize maximize and "X" control tab is missing from the drawing window when multiple drawings are opened. I have to tile to get them back to close the window.
Autodesk has not addressed this issue. Does anyone know how to fix this?
If you open HELP and look for ACCESS THE CLASSIC MENU BAR, you will see what I am looking at.
Except, the control tab for the program, top most right, in there. The drawing tab, just beneath, is not there. I tile the drawing, even if only one open, to get this tab to show up.
Windows 7.
Video card: Intel HD graphics 4600
thanks
jimmy
The upper control tab is the acad program. The blank grey is where the control tab is supposed to be.
This is what it is supposed to look like.
Only if the menubar is on though. Otherwise, it should appear in the drawing window, like this:
I have seen on occasion, where these controls did not show up like they were supposed to. Like maybe after you close a docked palette or something, and IIRC minimizing and maximizing the window made it come back. I would prefer if they used standard controls and quit embedding stuff like this in the drawing window.
Got more info.
1) Changed video card to new GE Force. Did not change.
2) When I split screen then maximize, the control tabs disappear, BUT
3) If I pan the drawing away from the right side, the control tab comes into view.
What the crap is this?
jimmy
So basically Acad has dumped their tech support for bugs onto users?
No wonder everyone I know is using Solidworks.
This is, as I understand it, a subscription service.
I will not pay for support for a program bug. This is Autodesk's problem.
They keep refering me to these forums for support. People, not the trolls, are really trying to help, but these are software problems. None of these existed with my old version on the same PC. Just after I upgraded.
Most of my problems I have worked around, but so far not one problem has been solved through these forums. But I do appreciate the effort.
Correct. I made the presumption that you were on subscription. If you are not then you support choices are limited to the peer-to-peer support here in the forums, or maybe via a support contract with an Autodesk VAR (reseller). You can also send feedback directly to the AutoCAD LT team using this form. Unfortunately, this is a one way conversation and you will most likely not receive a reply.
My personal thoughts on this particular issue are..... I've seen similar behavior and it just doesn't bother me that much. I can work around it without much effort. I have a laundry list of other things that rate much higher than this that I would like to see fixed.
Best of luck to you.
After further investigation, it seems that it is a known problem through at least 2013.
According to an autodesk tech, this is a known bug with no ETA for a fix.
