AutoCAD LT General Discussion
0 Kudos
Post 1 of 7
Measure
74 Views, 6 Replies
12-14-2011 07:02 AM
Have a conflict in my measure command.
Too many times (in the same drawing!!!) the measure would show wrong result (i.e. can show 1" as about 3' and change).
Anybody knows how to fix it?
Thank you.
*Expert Elite*
370 Kudos
Post 2 of 7
Re: Measure
12-14-2011 11:31 AM in reply to: sagishefer
Little more detail please.
Modelspace, Paperspace?
Units?
New / Old problem?
Elaborate
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
0 Kudos
Post 3 of 7
Re: Measure
12-14-2011 11:47 AM in reply to: Charles_Shade
Modelspace
Units are inches in architectural type.
Kind of been there every now and then.
Hope it helps.
Thank you.
Saga
*Expert Elite*
370 Kudos
Post 4 of 7
Re: Measure
12-14-2011 01:28 PM in reply to: sagishefer
Is this drawing from  Template or Scratch?
I'm wondering if you have Metric Settings in the somewhere. (SWAG)
MEASUREINIT should be 0 for Imperial.
Different DIMSTYLES by chance?
What is your Measurement Scale under the Primary Units tab in the Dim Style dialog.
1" to 3' is not an Imperial / Metric problem as the factor is too great.
0 Kudos
Post 5 of 7
Re: Measure
12-14-2011 01:40 PM in reply to: Charles_Shade
It is kind of a template as I am using the same basics repeatedly.
The measureinit is 0
I might have different DIMSTYLES but why would the MEASURE be affected by this?
The measurement scale is 1
*Expert Elite*
370 Kudos
Post 6 of 7
Re: Measure
12-14-2011 02:08 PM in reply to: sagishefer
Place a Dimension and then go and change the Measurement Scale for that Dim Style.
Now place the same Dimension again. It will be different.
Just a thought, not sure why you would show different dimensions in Modelspace. Should not happen.
0 Kudos
Post 7 of 7
Re: Measure
12-14-2011 02:09 PM in reply to: Charles_Shade
I'll try,
Many thanks
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
