AutoCAD LT Forum
Measure / Calculator tool in LT 2013
1 REPLY 1
1179 Views, 1 Reply
I'm using AutoCAD LT 2013, when I try to measure the length of a line using the measure tool, all I get is X and Y co-ordinates and not the length. Also if I try to use the calculator tool to measure the combined length of more than one line the software crashes. Is there a patch to correct this?
1 REPLY 1
Charles_Shade
Where are you not seeing the Length?
Is it at the Command Line?
If so; expand the Command Line to three or four lines rather than two.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
”Boost
