"Bob M." a écrit dans le message news:
4540CBEB975434158DC61FEBBAE2DA72@in.WebX.maYIadrTaRb...
> Hello,
> We will be going from R14 & LT98 to the 2000i level in a couple of days,
> with all the upgrades prepaid for 2k2. During our evaluation of the
> products, I noticed that most of the upgrades made were basically
> integrating tools from the earlier versions. Sort of like a testing
ground
> for new features. Can anyone tell me if a group that is used to using R14
> and LT98, will find LT2000i/2002 easy to adjust to? We don't want much of
a
> learning curve...
I am afraid there will be quite a learning curve...
410 new features between R14 and A2000...
Count 2 full days for that, and add 1 hour on top of that to switch from
A2000 to A2002.
Well, after having said that, it depends what you want to achieve.
You want to master A2002? From R14, that's a lot of work.
You want to be able to create and print a drawing in 2002 the same way you
did in R14?
You cannot do that, because you'll need to learn the new paper space layout
techniques and printing techniques... which are very different in R14 and
2000/2002.
But appart from the minimum time you will have to spend on printing
techniques (let's say half a day), you actualy can work in 2002 as you did
in R14 (this is not recommended because you'll miss the great 2000
improvements).
So my answer is: half a day is the minimum training time.
(I am an AutoCAD instructor)
(o)-(o)
---ooO---(_)---Ooo--------------------------
Afitec, centre de compétence AutoCAD à Lyon
http://www.afitec.com pemin@afitec.com
Communauté AutoCAD à http://communities.msn.fr/utilisateursAutoCAD
