I cut and pasted an image in from adobe using the snapshot tool. Now i want to draw on top. How can i make it unselectable. Using autocad lt 2009. in older versions you could right click and there was an option was to make it selectoable/unselectable.
I tried putting on a separate layer and locking and tried oleframe. it is still selectable.
thanks
pat
Welcome to the forums
At the command line type in IMAGEFRAME. Change the number to 0
If you need to reselect the image use the above command again, but change the number to 1
Howard Walker
No joy. I tried selecting the image and turning imageframe to 0 and tried without the image selected and turning imageframe to 0. Maybe i don't know what the snapshot cut from autocad is?
Pat
If you can post your drawing so we can have a look at it
Howard Walker
Drawing is attached. Just getting started and don't want to do much till I figure out how to manage the image or ole.
thanks
Pat
Right I've just had a quick look.
1. I see you are using the student version. Just be aware that you cannot use this drawing in a commerical version of Autocad because the plot stamp will appear on the commercial version as well.
2. OLEFRAME and change it to 0
Howard Walker
Thanks. I think that works. If you select the border it's still selectable, like with select window.
Pat
