AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Major problem with error message on opening AutoCAD LT 2010
5 REPLIES 5
JamesPowell7164
431 Views, 5 Replies
Guys
Opening AutoCAD LT this morning no problem. Closed it down and then opened it up again about 10 to 15mins later and get this message (see attached pdf). Can spomeone help me URGENTLY because I am in the mire if I cant use my AutoCAD.
Wiondows XP,anything else needed?
5 REPLIES 5
Closest item I found:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13109351&linkID=9240817
Did XP do an update to you?
If so a System Restore may set this right.
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Charles, went into blind panic mode and forgot to "google" itSmiley LOL
Thanks for your help - I will let you know if it works!
Thanks gain
JP
Charles
Thanks for your help. I think that it was a corrupt file but it seems to be OK now so keep your fingers crossed!
Thanks again
Just one file you think?
Did you try an AUDIT or RECOVER on it to open?
If that was the case I may have overreacted as well.
I know what it is like to see nothing when it was there before.
Charles
Once I had read your reply I googled the error message - which is basic really - but I was in a rush and under pressure to get some work out!
When I saw your reply it made sense and having googled it I think that the updates had corrupted a file. Typical Microsoft trying to help and then anonymous when something goes wrong. Thank goodness for you guys!
Gave you a kudos too!
”Boost
