AutoCAD LT General Discussion
New Member
simonbayley
Message 1 of 4 (114 Views)
Macro Help
114 Views, 3 Replies
05-01-2012 04:46 AM
Would someone be able to tell me why this won't work in LT 2013?
*^C^C_select;auto;\_copy;p;;0,0;0,0;_rotate;p;;_cen;\r;_cen;\\
It used to copy and rotate more than once.
I think the first p should be a d, but not sure about the rest.
TIA
Simon.
Waht is your PICKADD system variable set at? Initial value is 2 which screws up the SECECT command portion of your macro. If PICKADD is set to 2 change to 0 or 1. See the following link for more information on the PICKADD variable.
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ffa23ce210c4a30acaf-4f04.htm
Johneng
Message 2 of 4 (108 Views)
Re: Macro Help
05-01-2012 05:15 AM in reply to: simonbayley
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ffa23ce210c4a30acaf-4f04...
New Member
simonbayley
Message 3 of 4 (102 Views)
Re: Macro Help
05-01-2012 05:24 AM in reply to: Johneng
Perfect, thank you!!!!
I set it to 1 and it's fine now.
Charles_Shade
Message 4 of 4 (96 Views)
Re: Macro Help
05-01-2012 05:32 AM in reply to: simonbayley
Thanks for following up on the answer. That will help others to find a solution to this issue as well.
Something to keep in mind: Not all Variables will be set the same and/or Migrate properly when moving from one version to another. Often the previously used Macro or Drafting technique or whatever is the result of a Variable that was 1, 2, or 4271 and just needs to be set for the new Version. And being creatures of habit we just knew that it worked then and not now so it must be something wrong with the program and that Autodesk stinks when we simply forgot what we had setup two or three years ago.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
