Good afternoon folks (unless you're across the pond, in which case good morning)
When I click on a drawing blank border, the attribute box appears, but for some reason the attribute order has reversed. It used to be OK....
Is there any way I can reorder the attribute list WITHOUT having to delete them all and reinsert them in the order I require. I'm guessing it should be possible, especially as it reversed itself!
TIA
Solved by hwalker. Go to Solution.
I've never seen attributes re-arrange themselves in single block, all by themselves: the normal trigger is when a block is redefined and they are not deliberately selected in order.
Here are a few tips:
http://lynn.blogs.com/lynn_allens_blog/2010/01/an-autocad-hip-tip-on-attributes.html
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=5431
http://ltunlimited.typepad.com/my_weblog/2009/04/reorder-attributes-in-blocks.html
WOW that was a quick reply......
Thanks again Dean - I'll check out the links later, our great IT dept has deemed all such links as risky so I'll look when I get home.
Trusting the answer is there somewhere!
You could also try BATTMAN (which is Dean's third link)
Howard Walker
