As of 2 days ago, my LT2011 program crashes repeatedly with a Clr.dll error. I suspect this was a Windows update that has caused the conflict, but I have been unsucessful in finding a resolution. Any help would be appreciated.
The crashes are often and consistently repeatable. Usually about 2 minutes after opening program it crashes.
have your tired doing a system restore to 2 days ago?
DarrenP
Hello
Welcome to the Autodesk/AutoCAD Forums !
If you have an ACAD LT 2011, have you tried to install the SP1.1/Update1.1 and THEN the SP2/Update2 !?
Happy New Year and THE HEALTH !
Patrice BRAUD
I have installed the 2 updates recommended above last week. This seems to have corrected the issue. Thanks!
I am not on Windows 7/64, not XP and I do not have any Dell backup programs installed.
