Fix is here:
http://usa.autodesk.com/getdoc/id=TS16158933
But the description, as always, does not take into consideration us LT users with no LISP: you can use the screenshot on that page to guess where it is if you use Win7/Vista (replace stoekt with your Windows log-in name). For XP users, replace with c:/documents and settings/<your user name>/Application Data/Autodesk/AutoCAD LT 2011/R16/enu/support (my guess, someone in WinXP please confirm).
Solved by pendean. Go to Solution.
