AutoCAD LT Forum
LT2002 & LT2000
2 REPLIES 2
169 Views, 2 Replies
LT2002 & LT2000
I just installed 2002LT and left 2000LT on the computer. This was the
prechecked radio button on the install screen. My question is this: Is it
better to overwrite (upgrade) 2000LT or install 2002LT in its own directory?
Is OK to delete 2000LT without any problems to 2002LT?
Thanks in advance.
I have received a tremendous amount of tips from this group.
Tim
2 REPLIES 2
I don't recall how cleanly LT2000 can be removed in this case, but I
would always recommend a clean install over an overwrite/upgrade. If
you bought the upgrade version of LT2002, I'd recommend saving any
customized menu files to a safe location, then either a reformat or a
complete removal of all AutoCAD versions, then do a fresh install. If I
recall correctly, with LT95 the only thing that was required to be on
your computer was a valid aclt.exe. I think I remember reading that the
latest upgrades only ask to see the CD for a valid previous version, but
don't quote me on that.
My experience is that there can be enough junk left by previous versions
to cause some operational problems.
Martin
> Thanks in advance.
> Tim
LT2000 did not need to be on your machine in order to install LT2002: but
now that you have both, removing LT2000 will affect your LT2002. Doing a
repair install of LT2002 after you remove LT2000 should help fix it. Back up
your custom files first.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Tim Shea" wrote in message
news:BF67FED77585477C3A4BDF64BE36AD0C@in.WebX.maYIadrTaRb...
directory?
> Thanks in advance.
> Tim
”Boost
