I am running LT 2013. I have the Group Ribbon turned on and use it constantly. Until recently, whenever I would select the "Ungroup" button on the ribbon, a box would appear below the ribbon with a couple of button choices, "Accept" or something else (I'm drawing a blank on the other selection....sorry!).
I was looking at the shortcut list a couple of weeks ago, and went to turn off the command line (ctrl+9), and apparently entered the wrong command. In trying to undo my error, I probably entered some other commands, of which I have no idea what was entered. As a result, My "Ungroup" "Accept" button no longer shows up.
I know I just turned off a setting. But, I have been through the "Shortcut Key" list and I can't find it. I've been through the help listings with AutoCAD LT 2013, and I have looked through the forums to no avail. And turthfully,, there are other text readouts that I used to get when doing a command that seem to be missing too. However, for now, I'd just appreciate getting the "Ungroup" "Accept" button turnd back on. I'll worry about the other ones later.
If anyone knows what the command is to turn that button back on, and can offer assistance, would you please reply.
Any help would be appreciated.
Thanks.
Myron Grubaugh
Welcome to the Autodesk Forums!
FILEDIA set to 1 perhaps?
EXPERT set to 0?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
