Hi All,
I'm trying to configure HP designjet plotter on LT 2013 over win7.
Is it possible ?
Is HP 500 certified for LT 2013 ?
Do I have to install before on win7 or directly doing using LT 2013 ?
I'm using USB port connection.
Condor1959
Hp500 is old, LT2013 and Win7 are much newer: AFAIK you need to get better 64bit drivers for HP500 for it to work with any AutoCAD version in Win7. Check out the print-plot discussion area for many tips and issues with the old HP500 plotters and Win7: http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
I had an issue with the HP500 a few moons ago and found the thread. It may not be EXACTLY your problem but it IS possible to configure the HP-500 with ACAD2012. Not sure about 2013 (but then who is?)
Here is the thread that described my issue
Problem with the thread is that when I posted the driver I used I inadvertantly pasted a graphics driver link that was apparently residing on my clipboard.
The driver I used with Win7 x64 and ACAD 2012 was hpdj500wx64pclen.zip
It may not solve your issue but it may get you started in the right direction.
HTH
DJ
Yes, it is possible. It is not Autocad that is the challenge it is with Windows and an older technology in the plotter. As Pendean points out there have been numerous discussions about this already and you need to look there. There are solutions and it all has to do with getting rid of old drivers and then installing new ones.
