Hello; when i am using hatch/gradient edit with double clicking it started to not change when i pick some colors or patterns it shows what i choose but it doesn't apply on the drawing. what should i do ?
i have upload video about it if you don't understand the problem
here is the link ; http://www.youtube.com/watch?v=8BvfdCO3NVw&feature=youtu.be
😞 one more quick note; i tried to re-install but it doesn't change then i decided to format pc it is fixed but after a while it happened again...
It does not sound as if your PC has anything to do with this issue.
The responses read as if this is a glitch or bug in LT 2013 software and not something that can be corrected except from Autodesk.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
So it seems there is no chance to wait to Autodesk fix this ha ? The thing is if they know about this bug or whatever it is and will they fix it.
Until enough people report it and can reproduce it how are they to know? No one is perfect, not even you: we all find out our omissions and errors through others' feedback more often that from self discovery. It's how the world turns my friend.
Amazingly, I have yet to find a use for this feature in AutoCAD since it was introduced. Maybe I'm not a minority. Maybe I'm missing out on the next big hatching option 🙂
It should be fixed since it worked before hand. Report it.
yea of course i know no one is perfect, i just want to know if they consider one person's report bug since i search web widely for this issue and couldn't find anything to solve it even anyone suffering with this issue 😛 and i am using that command nearly as mush as line, anyway i ll wait and see thank you for your time mate.
P.S how can i report it ?
