AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
LT 2013 crashing in paperspace
10 REPLIES 10
Message 1 of 11
JF3905
442 Views, 10 Replies
Every time I try to amend attributes in my title block in paperspace AutoCAD freezes. Any ideas?
10 REPLIES 10
Message 2 of 11
Charles_Shade
in reply to: JF3905
One drawing or all drawings?
Does the Titleblock itself work properly? I am assuming it is a seperate Drawing or Template.
Do you INSERT or XREF this Title block? Same assumption as above.
Message 3 of 11
pendean
in reply to: JF3905
"amend": what command would that be? A double-click, or are you actively launching a command? Try the latter.
Message 4 of 11
JF3905
in reply to: Charles_Shade
All drawings it appears. The title block dwg seems to be ok. It sits on the paperspace of one of my dwt's. The problem occurs when I right click on the block, edit attributes, make the changes then click ok - the cross hair will then not move and AutoCAD is frozen.
Message 5 of 11
Charles_Shade
in reply to: JF3905
Have you run AUDIT or RECOVER on the DWT?
Go back to the original DWG file that you use for this Titleblock. Do you have it or is it just part of this Template?
Message 6 of 11
JF3905
I have run AUDIT on the dwg itself (which is a separate drawing) and reinserted it into one of my dwg's and the same problem.
Message 7 of 11
Charles_Shade
in reply to: JF3905
WBLOCK that drawing into a new file.
Post it here as well if you can.
Message 8 of 11
JF3905
That has not worked either.
Message 9 of 11
Charles_Shade
in reply to: JF3905
No problems with your drawing here. Opened fine. Block Editor just fine. Insert and right click to Edit Attribs just fine.
Added values to the Attribs just fine. Right clicked and changed Attribs just fine.
Audit showed no errors.
WBLOCK to new file and no problems.
Message 10 of 11
JF3905
Thanks for checking. SP2 update has resolved the issue.
Message 11 of 11
Charles_Shade
in reply to: JF3905
”Boost
