Every time I try to amend attributes in my title block in paperspace AutoCAD freezes. Any ideas?
Solved by JF3905. Go to Solution.
One drawing or all drawings?
Does the Titleblock itself work properly? I am assuming it is a seperate Drawing or Template.
Do you INSERT or XREF this Title block? Same assumption as above.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Have you run AUDIT or RECOVER on the DWT?
Go back to the original DWG file that you use for this Titleblock. Do you have it or is it just part of this Template?
WBLOCK that drawing into a new file.
Post it here as well if you can.
No problems with your drawing here. Opened fine. Block Editor just fine. Insert and right click to Edit Attribs just fine.
Added values to the Attribs just fine. Right clicked and changed Attribs just fine.
Audit showed no errors.
WBLOCK to new file and no problems.
Glad it was an easy fix
