AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
LT 2012 Publish Command - Default Folder
1 REPLY 1
gordonc
322 Views, 1 Reply
I can't see any way of doing it so I thought I would ask.
Is there any way to have the Output PDF default folder always match that of the DWG you are producing the PDF from?
Commands _exportsettings _options
It's only a few clicks each time to find the folder you need but it would be useful if this option existed.
1 REPLY 1
pendean
in reply to: gordonc
Not an option: it requires a hard-coded location for Export and Publish functions.
”Boost
