I can't see any way of doing it so I thought I would ask.
Is there any way to have the Output PDF default folder always match that of the DWG you are producing the PDF from?
Commands _exportsettings _options
It's only a few clicks each time to find the folder you need but it would be useful if this option existed.
Solved by pendean. Go to Solution.
