ACAD LT 2011 started having random crashes, I am running windows 7. Always get the same application errors. Any ideas out there ??
Faulting application name: WSCommCntr2.exe, version: 3.0.269.0, time stamp: 0x4c0c8ae0
Faulting module name: ntdll.dll, version: 6.1.7601.18229, time stamp: 0x51fb164a
Exception code: 0xc0000005
Fault offset: 0x000000000004e4e4
Faulting process id: 0x1cd4
Faulting application start time: 0x01d03ab50c1e7039
Faulting application path: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr\lib\WSCommCntr2.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 4aa0fde3-a6a8-11e4-8604-00262df6a716
Faulting application name: acadlt.exe, version: 24.1.208.0, time stamp: 0x4dbfa352
Faulting module name: clr.dll, version: 4.0.30319.18063, time stamp: 0x526767d0
Exception code: 0xc00000fd
Fault offset: 0x00000000004e9c50
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report Id: %13
Hello
Welcome to the Autodesk/AutoCAD Forums !
1) You can rename this .EXE file to something like .XXX
And then relaunch ACAD LT 2011 to see ...
2) Maybe you could update your ACAD LT 2011with Update/SP 1.1 :
And THEN with Update/SP 2 :
3) I imagine something has moved (or been updated) on your PC and/or Windows 7 !?
Because if you haven't any probleme before !
So maybe Windows Update is ON ??
Can you restore your Win Seven to a previous date when everything was OK !?
Patrice BRAUD
