AutoCAD LT Forum
LT 2008 - Menu not loading when I open it up
3 REPLIES 3
myparentskid
235 Views, 3 Replies
When I start up LT2008, I get a blank screen, but by menu is not laoding (it used to).
I have to open the <File> tab and the it has an menu option I can them load my .cui menu
Did I toggle something?
Help, thanks...
3 REPLIES 3
pendean
in reply to: myparentskid
Reselect your workspace perhaps: or after you get back your screen menu manually, then save your current workspace with WSSAVE command.
myparentskid
in reply to: pendean
I tried that, no avail...
I talk about when I start AutoCad there is nothing there, toolbars are gone..
I have a custom menu system I designed, it used to load whenever I started it up, now i have to go in and manually load it each time.
pendean
CUILOAD command, load your custom menu file, then save your active workspace: unless you have some customized startup shortcut that is sabotaging LT that is how it works.
”Boost
