I must have done somehting or changed a setting....
I used to be able to select multiple objects to move, copy, delete, etc. just by clicking on them. I could click on as many objects as I wanted.
Now, seemingly out of nowhere, I can only select one object, unless I hold down the shift key. When I click on a second object, the first object "UN-selects". Now, to select multiple objects, I have to hold down the shift key. I know I didn't have to do that before.
Is there a box I checked or unchecked, or is there a setting I switched without realizing it?
Solved by Charles_Shade. Go to Solution.
PICKADD Variable
You set it to 0 at some point.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
