AutoCadLT2012 has deleted the data from all the files I was currently working on. The files are there and the backup is there , but all data has been removed. I have searched my entire computer (three hard drives) and Acad backup, auto save, etc. and the files are there, but no dwg
I have just had a weeks work lost. ANY SUGGESTIONS WILL BE GREATLY APPRECIATED
Are you sure they where there to start with?
Do you just need to Zoom and pan around? Or simply repath and reattach the Xref files?
Post one that you know is still good, we all have AutoCAD/LT from many versions.
There could be an enitity a Parsec or so away and therefore everything if initessimal.
SaveAs a new File to test.
ZOOM, Extents
SELECT, All
A blue dot on opposite sides of the Workspace?
Delete one and then ZOOM, Extents again.
If you got the wrong one Undo and try the other...
Please mark any response as "Accept as Solution" if it answers your question.
Kudos + gladly accepted if you are feeling magnanimous
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Sorry dude - been there and its gone.
