AutoCAD LT Forum
Locating Origin in Model Space
3 REPLIES 3
18213 Views, 3 Replies
Hello!
(ACAD LT 2012)
I can't seem to locate the 0,0 (ORIGIN) in Model space.
SCENARIO 1:
I create a line > specify second pt to 0,0 > Enter = NADA
SCENARIO 2:
Create a Line > Select Line > Move to 0,0 = NADA
HOWEVER, If i create something, use COPYBASE command, and and specify 0,0 --> PASTE into new drawing with 0,0 as insertion point, it can locate it... so it's there.... i just can't find it.
Please help, thx!
-- gxl
3 REPLIES 3
pendean
http://ltunlimited.typepad.com/my_weblog/2008/08/absolute-vs-rel.html
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11753684&linkID=9240815
Be more specific when typing out coordinates in LT, that way you avoid odd settings in files:
@x,y for relative
#x,y for absolute
See if that helps.
in reply to: pendean
Thank YOU, Dean!!
This may sound lazy, but I do NOT want to type in #.
I've never had to do this (being specific) before using other acad version.
However, the first link you provided solved my problem -- once I found where Dynamic Input was located.
step-by-step Solution:
Selection Cycling (CTRL W)  >   RT CLK Settings > Dynamic Input > Settings for POINTER INPUT  > Select ABSOLUTE COORDINATES.
Background Extras:
I trried to move something to 0,0 (before solution):   FAIL
Co-Worker #1 attempts same thing on her machine using same drawing:  SUCCESS
Co-Worker #2 attempts same thing on her machine same drawing:  FAIL
OPEN new drawing and attempt to locate 0,0:  FAIL
Co-Woker #2 finds Survey from consultant.  Attempts to locate 0,0 using her machine:  SUCCESS (weird since she couldn't do it in the previous drawing)
All 3 of us check our POINTER INPUT SETTINGS to see if it's a settings issue or drawing issue.  All of us have RELATIVE COORDINATES Selected.... (weird right?)
pendean
That's why I posted the links 🙂
”Boost
