Dynamic Blocks Forum
Linking a dynmaic block flip parameter to a field
1 REPLY 1
S7v7n
266 Views, 1 Reply
Hi
Can anyone help? I have created a dynamic block of a standard fridge with various attrubites, is there a way I can link the flip parameter so when the door is flipped it will read either RH or LH in the attribute prop table as this will help when I extract the data.
I have tried attaching a field to 'attribute 09_Model' but it only shows either 0 or 1 as it is fliped
block attached
1 REPLY 1
steven-g
in reply to: S7v7n
Try this I added a lookup and used that in the attribute field, you can change the value by changing the lookup string in the lookup table.
I also had to change FIELDEVAL is there a reason you had it set to zero, it took me ages to figure out why things weren't working as I expected.
”Boost
”Tips
”Services
