I'm trying to plot a line weight defined by a CTB Plot Style, but the weight will not show in AutoCAD or print.
Here's what I've done;
-Set the line weight in the Plot Style Table Editor, Color 9 @
0.40mm. Grayscale has been turned on.(All other settings have
been left as default)
-Tried various combos like;
-selecting "Display plot styles" & "Plot with Plot Styles" in pg
setup
-selecting the "Plot object lineweights". (It also turns off
"plot with plot styles" and prints in color (though grayscale is
on)
-LWDISPLAY has bee turned on
-Neither model or paper space reflects the change.
-Line types work fine
-Changing the same line thru the Properties Manager does the
trick, but I would like to set it up properly thru the Plot Style
Back Ground Info;
-Both the dwg file and Plot Style are new and created from
scratch.
If it was a printer issue, it would still show in AutoCAD correctly, right? I've searched various help tools, but seem to be going in circles. I'm sure it's a simple step I'm missing, but would like help to pin point it.
Thank you in advance.
