I am trying to embolden lineweights to stand out on the drawing, without them getting in the way when viewing in the drawing. I have set the lineweight in the layer dialogue box to the max size (2.xx mm), checked the "plot lineweights" in the printer dialogue and switched between none and grayscale (this is so the assigned colors will fade out in the background). Nothing I have tried thus far has changed the print output on any of my printers (virtual PDF, HP2100, HP2600n, HP2840 they are all very old). Any thoughts? I have read through the lweight command and help sections, but I don't need help assigning the lw just getting it to properly print.
One possible problem: is the line weight relative to scale or is it absolute? I am printing at 1/8" scale, and that can't change. Any help is appreciated.
Solved by madcowscarnival. Go to Solution.
Solved by pendean. Go to Solution.
pendean, thanks it was the bylayer setting.
The post was light on information because I have typically filled the need for lineweights with pwidth and know very little about plot command handling lineweights or plot tables (though it is something that I am trying to bring up to speed). The last time I was up to speed on lineweight settings was assigning pens and colors on our old pace plotter with v14.
Here's a spin off this:
I have a layer in an xref. I set the layer lineweight to the maximum. All objects are set to lineweight bylayer. LWDISPLAY is set to ON. Plot object lineweights is on when I go to plot. I am plotting with a .ctb for style, the color of the layer in question is 180. Color180 is set in the plot style table to use object lineweight for lineweight. The lineweight doesn't display and doesn't plot. What could I be missing?
