If you've assigned Linetype Scales directly to the entities, the PSLTSCALE
setting won't change the display in Layout tabs. You would have to change
the Linetype Scale on each entity back to 1, then PSLTSCALE will work. Of
course the downside is that when you go back to the Model tab, you won't see
the linetypes properly.
HTH
Carl Von Stetten
Central Contra Costa Sanitary District
cvonstetten@centralsan.dst.ca.us
"Jeff S" wrote in message
news:2C984A1E79D2E74D60D496930B5579E5@in.WebX.maYIadrTaRb...
> Still struggling...I have about a dozen dashed lines in my drawing. In
> model space I set the Linetype Scale to 48 for only those lines because I
> will print at that scale, and they are visible in model space as dashed
> lines. But then they are at the same scale in paper space and I can't see
> them. If I change the scale in either paper or model space it changes the
> scale in both. In paper space, if I set LTSCALE to 1 and PSLTSCALE to 1 I
> still don't get visible dashed lines. Am I executing the commands wrong?
> Do I have to actually select all the dashed lines while in paper space and
> change the scale to 1 that way, because that seems to work. But there
must
> be an easier way than trying to remember which lines are dashed and then
> manually selecting them and changing the scale. Yes, I'm a beginner, so
> thank you for your patience and help.
> "Dave Byrnes" wrote in message
> news:2728D46F4F476CE8BA00304189AD3CCD@in.WebX.maYIadrTaRb...
> > Sounds like you're not using paper space linetype scaling...
> > In model space, the LTSCALE variable is related to the ultimate plot
> scale.
> > If you're plotting at 1:48, then LTSCALE might be 24 to 48.
> > To use paper space linetype scaling, relate LTSCALE to the plot scale;
> i.e.,
> > 1:1 -- so make LTSCALE 0.5 to 1.0. Then set the PSLTSCALE variable from
0
> to
> > 1.
> > Dave Byrnes/Vancouver BC
> > Autodesk Forum Moderator Program
> > Please DO NOT send technical requests to me via private e-mail.
> > Use CTRL+G to reply and KEEP IT IN THE NEWGROUP!
> > Jeff S wrote in message
> > news:3BF225EEAA6FE56F51F5D25C2AE7BC66@in.WebX.maYIadrTaRb...
> > > If I print from model space, all my non-continuous linetypes print
> > correctly
> > > (e.g., dashed lines). But using the Layout tabs, all of the
> > non-continuous
> > > linetypes show up on the screen as continuous, and they print as
> > continuous.
> > > What am I doing wrong?
