Q: When drawing a line (linetype HIDDEN), after select it give right click on it and the properties box General -> Linetype scale and set value example 2 line does not change? I use AutoCAD LT 2014, with earlier versions 2012 and lower there was no problem
Solved by drjohn. Go to Solution.
Welcome to the Autodesk Forums!
All drawings or just this one?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
All drawings.
I saw something else that might explain things. When I select an object (line) in the properties box does not show the selected object.
Sounds like the usual ye olde PICKFIRST system variable setting.
@Anonymous wrote:
All drawings.
As for the PROPERTIES PANEL, it would seem a registry cleaner was run on the box and it removed some ACAD registry settings.
SOLUTION: Repair install from the Windows Control Panel and try CCLEANER for a reg cleaner.
HTH
DJ
