AutoCAD LT Forum
Linetype scale
7 REPLIES 7
Message 1 of 8
engineer
842 Views, 7 Replies
Linetype scale
Q: When drawing a line (linetype HIDDEN), after select it give right click on it and the properties box General -> Linetype scale and set value example 2 line does not change? I use AutoCAD LT 2014, with earlier versions 2012 and lower there was no problem
Tags (2)
7 REPLIES 7
Message 2 of 8
Charles_Shade
in reply to: engineer
Welcome to the Autodesk Forums!
All drawings or just this one?
Message 3 of 8
pendean
What are your settings in LT2014 and 2012 (and earlier) for:
LTSCALE
CELTSCALE
MSLTSCALE
PSLTSCALE
CANNOSCALE
Message 4 of 8
engineer
in reply to: Charles_Shade
All drawings.
I saw something else that might explain things. When I select an object (line) in the properties box does not show the selected object.
Message 5 of 8
engineer
in reply to: pendean
I use the command LTSCALE everything works, but the problem with the selection remains
Message 6 of 8
dgorsman
Sounds like the usual ye olde PICKFIRST system variable setting.
Message 7 of 8
pendean
Nothing to do with PICKFIRST variable: looks like you ran a WIndows Registry Cleaner (or your WIndows Registry is truly messed up) and it wiped out AutoCAD's entries.
You have to repair reinstall AutoCAD: no other solution sadly unless your cleaner app has a darn good restore feature.
Message 8 of 8
drjohn
@Anonymous wrote:
All drawings.
As for the PROPERTIES PANEL, it would seem a registry cleaner was run on the box and it removed some ACAD registry settings.
SOLUTION:  Repair install from the Windows Control Panel and try CCLEANER for a reg cleaner.
HTH
DJ
”Boost
