AutoCAD LT General Discussion
redwhiteblue
Message 1 of 7 (2,958 Views)
Lines drawn on defpoint layer, unable to erase or move.
2958 Views, 6 Replies
07-28-2010 07:09 PM
I'm working with someone else's drawing and I'm having a problem with the defpoint layer,  here's the problem:  I open the dwg. in model space, switch to paper space, insert my title block, switch the layer to defpoint, draw a viewport window, everything looks good except I can't move, resize, erase, or do anything with that viewport window, it's like it's frozen, won't even let me pick it, what's wrong here?  Can someone help me?  I'm using autocad lt 2007.
Active Contributor
M-Town_Drafter
Message 2 of 7 (2,943 Views)
Re: Lines drawn on defpoint layer, unable to erase or move.
07-28-2010 10:46 PM in reply to: redwhiteblue
Is layer 0 frozen or off?  Defpoint items will be visible but unselectable when layer 0 is frozen or turned off.
Joe P.
BernardMadoff
Message 3 of 7 (2,941 Views)
07-28-2010 11:25 PM in reply to: redwhiteblue
make sure the layer is not locked
redwhiteblue
Message 4 of 7 (2,927 Views)
07-29-2010 05:22 AM in reply to: BernardMadoff
The layer defpoints is neither locked, frozen, or off.  Have you any other suggestions?  Thanks for any help.
*Expert Elite*
pendean
Message 5 of 7 (2,925 Views)
07-29-2010 05:25 AM in reply to: redwhiteblue
Thaw and turn on layer 0 (zero) as the first reply noted.
If you still cannot erase those objects, they are part of a block, thaw/turn on all layers and unlock them and try again.
If all the above fail (I noted two things to try), post your DWG file here or send it back to the originator to fix for you.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
redwhiteblue
Message 6 of 7 (2,904 Views)
07-29-2010 11:57 AM in reply to: pendean
Thanks for everyones help on this issue,  I ended up just starting over and got rid of that dwg. file, things are working fine now.
*Pro
Modman_4
Message 7 of 7 (2,873 Views)
07-31-2010 01:31 PM in reply to: redwhiteblue
Next time OP, especially if you stand to lose a lot of work, there are a number of viable possibilities to try, starting with the advice about layer zero. Starting from scratch should be a last resort!
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
