When I plot a drawing on a particular file there is a line on my dimension layer that doesn't appear at any other time. It only plots when the dimension layer is on but does not appear on the screen so I cannot select it and delete it. The layer itself seems to be normal like the other layers. Are there any remedies besides creating a new layer and putting the dimensions on the new layer? I have this problem on one other file that I see so far.
Solved by lokimeister. Go to Solution.
Post the offending drawing, and also post a screenshot with the area where the line is supposed to be highlighted.
Howard Walker
And try a WBLOCK of the File.
These ghost lines have been solved using that Command.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Are you able to post the drawing for us to look at?
I decided to just create a new layer and turn off the offending layer.
Thanks.
