Make your arrow into a block, or you can decide to use one of the built-in
arrows in DIM, then start the DDIM command, MODIFY button, and change the
leader arrow block to what you want. then you can use LEADER. QLEADER gives
you nicer options too if you want to explore it.
HELP can explain usage of DDIM, LEADER and QLEADER.
Dean Saadallah
www.pendean.com
"Michael Serbousek" wrote in message
news:6BC47378C23B7A44A09006DD77B1CACF@in.WebX.maYIadrTaRb...
> I think I should clarify myself. I would like to control the width of the
> back part of the arrow. When I first started here the draftsman was
> manually drawing each arrow and didn't know about the leader command. He
> would draw a triangle then fill it with a hatch. I would like to be able
to
> use the leader command to reproduce these type of arrows since there are
> already thousands of them. What I have been doing is use the leader
command
> and then explode the leader and stretch it to represent the arrow that the
> other draftsman used.
> news:319B059950BBBC6C8692D13E83D704DE@in.WebX.maYIadrTaRb...
> > Is there any way under Dimension Style Manager to also control the
width
> of
> > a leader, one can specify the length but it would also be nice to
control
> > how wide the leader is.
