>Duplicate definition of block .... ignored.
Nick, this tells you that there already is a block of this name in the
drawing. And this results in your title block remaining the same.
You first need to eliminate the block from the drawing. To do so, find
every insertion of the block and delete it, then purge the drawing. Do
so for every block duplicated.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
