Hey Guys, I (and others) have been having problems with our layer manager "crashing" I guess you'd say, it doesnt happen everytime, but it does happen often.
Basically when i open layer manager all the layers are "gone" but if you click anywhere you can see they're visibility is just sort of switched off. Ive attached a screenshot so if anyone can assist me with this, that would be awesome.
p.s. yes classiclayer works fine, but its more cumbersome and i dont really want to use that if i can fix my usual layer manager.
Ive also toggled with windows display settings cranking down the graphics (as i thought i had read somewhere that might work) but it didnt help either.
no its not the files as it's happening to multiple users across a multitude of files, our version is LT 2015 and fully updated (it was happening with the 2013 version as well) running on windows 7 professional, ive tried a reinstall but that didnt fix anything. my instincts are telling me its a graphical error but i dont know what i can change to fix this issue
Hello
Welcome to the Autodesk/AutoCAD Forums !
A few ideas :
1) Have you tried to run WITH and WITHOUT Graphic Hardware Acceleration ?
Does it make some difference ?
2) Are you using Layername and/or Filename (XREFs) with special characters ?
Because when using only A-Z , 0-9 , _ , - characters , it's much better !
Patrice BRAUD
